What kind of features do I get with the Arlo Pro 3 camera?
Arlo Pro 3 is a wire-free camera that records 2K video. The camera comes with several new features to enhance your home security experience. These features include:
  • 2K video resolution with high dynamic range (HDR)
  • Auto Zoom and Tracking
  • Color night vision
  • An integrated spotlight
  • 160-degree field of view
  • An integrated siren
  • A free Arlo Smart subscription trial
2K Video Resolution with HDR
The Arlo Pro 3 camera records in 2K for higher-quality video. It also uses high dynamic range (HDR) to capture clear, highly detailed images.
For more information, visit How does my Arlo Pro 3 camera use 2K?.
Auto Zoom and Tracking allows for enhanced focus on moving objects with increased clarity and detail. When Arlo Pro 3 detects motion, it zooms in and tracks the movement while the object is within Arlo Pro 3’s field of view.
Note: When Auto Zoom and Tracking is enabled, video recorded to the Cloud and USB drive will be in 1080p resolution.
Color Night Vision
Color night vision on Arlo Pro 3 enables you to see night-time activity in color and with better quality.
For more information, visit What does color night vision mean?.
Integrated Spotlight
Arlo Pro 3 comes equipped with a built-in spotlight that activates when motion is detected within Arlo Pro 3’s field of view. You can activate the spotlight manually within the camera’s live stream menu on the Arlo app.
For more information, visit How does the spotlight on my Arlo camera work?.
Arlo Pro 3 has a 160-degree diagonal viewing angle. You can adjust the field of view on the Pro 3 to 160, 125, or 110-degrees field of view.
Integrated Siren
Arlo Pro 3 comes with a built-in siren that can be triggered remotely or automatically as a mode for the camera.
A Complimentary Arlo Smart Trial
If you purchase an Arlo Pro 3 camera, a 3-month Arlo Smart trial with 2k Cloud Recording is included.
