How do I change the battery in my Arlo Pro 3 Floodlight Camera?
The Arlo Pro 3 Floodlight Camera is made of two parts. The camera and battery are together in one part, and the camera housing acts as a protective shell in a second part. Replacing the battery in your Arlo Pro 3 Floodlight requires you to remove the camera from the camera housing.
To change the battery in your Arlo Pro 3 Floodlight Camera:
- Press the battery access button on the charging port underneath the camera housing.
A clicking sound occurs, and the camera begins to slide out of the camera housing.
Note: Keep a hand on the camera and camera housing to prevent the camera from falling when you press the battery access button. - Pull the camera until it is entirely removed from the camera housing.
- Remove the battery by pulling on it until it slides out of the camera.
- Align the new battery and insert it into the battery compartment.
Note: The battery only inserts one way.
The camera’s status LED blinks blue after the battery is inserted.
- While holding the top and bottom of the camera (not the lens or light), insert the camera back into the camera housing until it clicks into place.
Note: Pressing on the camera lens or light might leave smudges or damage equipment.
Your Arlo Pro 3 Floodlight Camera is ready to resume normal activity.
For more information, visit Arlo Pro 3 Floodlight Camera Product Tour.
