Illuminate up to 8 meters of your property with 3000 lumen LEDs that are brighter than car headlights.
*Apple HomeKit requires a separate SmartHub
Powerful Floodlight
Real-time Talk
Built in speaker & microphone lets you speak to family and visitors or warn off intruders as if you were there yourself.
Colour Night Vision
Bright colour night vision helps you identify details, like faces and clothing, more easily, even in the dark.
Realistic Video
Powerful 2K resolution gives you sharper, more realistic video so you can see what's happening around your home.
Loud Siren
Scare off intruders with the built-in 80 db smart siren that can be heard up to 30 metres away. Have it automatically go-off if motion is detected or trigger from the app to quickly raise the alarm.
100% Wireless
Unbox and go. 100% wireless means you can set-up and start protecting your home in minutes - with no need to wire into mains power.
React & respond
Choose how you want to respond to an alert – hear and speak to visitors with 2-way audio or trigger the siren to deter intruders.
Power options
Use the long-lasting, rechargeable battery or pair with an Arlo Solar panel or outdoor charging cable for continuous power.
Arlo Secure Subscription
Advanced Security Monitoring from just 35DKK per month
An Arlo Secure subscription gives you access to market leading security features and secure cloud storage
Still have questions?
