How do I adjust Arlo video recording length? - Arlo Secure 4.0
Most Arlo cameras can record until activity stops, up to 5 minutes. If you set the camera to record until activity stops, the camera will record as long as it detects audio or motion (up to 5 minutes). If the event exceeds 5 minutes, a new recording will start. You can also set your Arlo cameras to record videos for a fixed length from 10 seconds to 2 minutes long. Recording requires either an Arlo Secure subscription or local storage.
For more information, visit:
- What is Arlo Secure and how can I benefit from it?
- How do I enable or disable local storage for my Arlo SmartHub or Base Station - Arlo Secure 4.0
To adjust Arlo video recording length:
- Launch the Arlo Secure App.
- Tap Devices.
- Select the device you want to adjust.
- Tap
- Tap Default Mode Settings.
- Under RECORDING LENGTH, select between Record until activity stops for recording length up to 5 minutes, or Record for a fixed length. Move the slider to adjust the recording length from 10 seconds to 2 minutes.
