Arlo Essential Indoor Camera (2nd Generation) FAQ
This FAQ applies to the new Arlo Essential Indoor Camera 2K and HD (2nd Generation).
What is the Arlo Essential Indoor Camera (2nd Generation) video resolution?
2nd Generation Arlo Essential Indoor Cameras have video resolution of 1080p and 2K.
What is the field of view on the Arlo Essential Indoor Camera (2nd Generation)?
The Arlo Essential Indoor Camera (2nd Generation) field of view is 130-degrees.
Does the Arlo Essential Indoor Camera (2nd Generation) have an integrated siren?
Yes. The siren can be set to trigger automatically when motion or sound is detected, or enabled manually with the Arlo Secure App. For more information, visit: How do I turn the siren on my Arlo camera on or off? - Arlo Secure 4.0
How do I mount the Arlo Essential Indoor Camera (2nd Generation)?
You can use the included mounting plate to mount the camera on a wall, or you can place the camera on a flat surface.
Do I need an Arlo SmartHub or Base Station to use the Arlo Essential Indoor Camera (2nd Generation)?
No. You can connect the Arlo Essential Indoor Camera directly to your 2.4 GHz Wi-Fi network without the need for an Arlo SmartHub or Base Station.
What is the minimum upload bandwidth speed required?
The Arlo Essential Indoor Camera (2nd Generation) requires an upload speed of at least 2 Mbps per camera. For more information, visit: What are the minimum requirements for installing and using my Arlo system?
Can I use continuous video recording (CVR) with the Arlo Essential Indoor Camera (2nd Generation)?
Yes. You can purchase a separate CVR subscription to continuously record with your Arlo Essential Indoor Camera.
Is an Arlo Secure trial included with the Arlo Essential Indoor Camera (2nd Generation)?
Yes. A 30-day Arlo Secure trial is included with the purchase of an Arlo Essential Indoor Camera (2nd Generation).
What is the Privacy Shield?
The automated Privacy Shield closes whenever you disarm your camera, ensuring that your moments are private when needed.
What happens when the Privacy Shield is enabled?
When the Privacy Shield is closed, your camera disables motion and audio detection, and the camera’s microphone is turned off.
Can I close the Privacy Shield manually?
No. You can close the Privacy Shield in the Arlo Secure App by disarming your camera. Do not attempt to manually close the Privacy Shield with your finger.
Last Updated:12/16/2023 | Article ID: 000063191
