How do I change the motion sensitivity on my Arlo camera?
To adjust the motion sensitivity on your Arlo camera:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
  2. Tap or click Mode.
  3. Select the device you want to adjust.
  4. Tap or click the pencil icon next to the mode that you want to edit.
  5. For Arlo Ultra, Arlo Wire-Free, and Arlo Pro cameras, tap or click the pencil icon next to the rule that you want to edit.
  6. Tap or click the pencil icon next to If Motion or Audio.
  7. Move the slider to adjust the motion sensitivity.
  8. Tap or click Save.
  9. Tap or click < to return to Edit Mode.
  10. Tap or click Done.
Your motion sensitivity settings are saved.
