| Regulatory | FCC, CE, IC, RCM compliant |
Dimensions
| Camera | 218.5mm x 190.5mm x 77.9mm |
| Weight with Battery | 650g |
| Wired/Wire-Free/Both | Both |
| Requirements | High-speed Internet Cennection |
Specifications
| Max Video Resolution | 2560x1440 resolution |
| Image Sensor | 4 megapixels |
| Video Modes | 2K, 1080p, 720p |
| Video Features | Auto Track and Zoom, HDR, H.264 and H.265 Encoding |
| Feld of View | 160° diagonal |
| Sensor size | 1/3” |
| Light Type | Floodlight |
| Light Color Temperature | 4000K |
| Efficacy/Brightnes | 2000-3000* lumens (*Outdoor Magnetic Charging Cable required for 3000 lumens) |
| Light Modes | Constant and pulsate |
| Motion Detection | Single Motion Detector, 130 degree horizontal |
| Siren | Built-in |
| Night Vision - Color | Yes |
| Night Vision – Black and White | 2 High Powered Infrared |
| AC Adapter Output | 5V 2A |
| AD Adapter Input | 100-240V AC, 50/60Hz |
| Indoor/Outdoor | Both - outdoor UV and weather-resistant |
| Digital Zoom | 12x |
| Microphone | Single Microphone with noise and echo cancellation |
| Audio | Full Duplex 2 way Audio |
| Status Lights | Dual colored LED |
| Networking | 802.11 b/g/n |
| Compliant Standards | 128-bit SSL, AES-128, TSL, 2 factor authentication |
| Battery Type | Re-chargeable |
| Charge Time to Full (via camera) | 6.5 hrs |
| Charge Time to Full (via charger accessory) | 5 hrs |
| Operating Temperature | -20 to 45 degree Celsius |
| Connectivity | Wi-Fi Connection. Working broadband connection with at least 2Mbps upload speed |
| USB requirements | N/A |
| Minimum upload speed | 2-4Mbps |
