What do the LED behaviors on my Arlo Go 2 Camera mean?
The LED indicates the status of the Go 2 camera.
LED behavior during setup
Slow blinking blue: The camera is attempting to connect to a WiFi network or is in QR scanning mode.
Fast blinking blue: The camera is establishing a WiFi or LTE network connection.
Fast blinking amber: The camera did not connect to the WiFi network or it did not connect to the LTE network. For help with Arlo Go 2 network connections, visit What do I do when Arlo does not discover my device during setup?
Solid amber: The camera does not detect an activated SIM card in its SIM card slot. For more information, visit How do I install a SIM card in my Arlo Go 2 Camera?
LED behavior after setup
Solid blue: The LED lights solid blue when the camera is powered on and then turns off to conserve battery power.
Note: the camera does not record continuously since it needs to conserve battery power.Fast blinking blue: The camera’s charging cable is plugged in to a power adapter or the camera is connected to the optional Arlo Solar Panel VMA5600.
Single blink or double blink amber every 60 seconds: The battery charge is low. A single blink every 60 seconds indicates a low battery charge. A double blink indicates a critical battery charge level.
Alternating blue and amber: A firmware update is in progress.
Single blink amber, followed by restart: The camera has been factory reset. For more information, visit How do I factory reset and re-sync my Arlo camera?.
