How do I completely remove my Arlo Pro 3 Floodlight Camera from the wall?
Before you begin, you need a Phillips-head screwdriver to remove your Arlo Pro 3 Floodlight Camera from the wall. You can use the same screwdriver that you used to install the camera to the wall.
Note: To charge your camera indoors, you do not need to remove the entire camera and mount. For more information, visit How do I charge my Arlo Pro 3 Floodlight Camera?.
To remove your Arlo Pro 3 Floodlight Camera from the wall:
  1. Use a Phillips-head screwdriver to loosen the screw at the bottom of the camera housing’s grip.
  2. Turn the camera housing counter clockwise, and pull it from the back plate.
  3. Unscrew the screws from the wall plate, and remove the wall plate from your wall.
