How do I change the motion sensitivity on my Arlo camera?
To adjust the motion sensitivity on your Arlo camera:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Mode.
- Select the device you want to adjust.
- Tap or click the pencil icon next to the mode that you want to edit.
- For Arlo Ultra, Arlo Wire-Free, and Arlo Pro cameras, tap or click the pencil icon next to the rule that you want to edit.
- Tap or click the pencil icon next to If Motion or Audio.
- Move the slider to adjust the motion sensitivity.
- Tap or click Save.
- Tap or click < to return to Edit Mode.
- Tap or click Done.
Your motion sensitivity settings are saved.
