How can I reset my Arlo SmartHub or base station to the default values?
WARNING:
To perform a factory reset on your Arlo Base Station or SmartHub:
- Use a pen or straightened paperclip to press and hold the Reset button on the back of the Base Station or SmartHub for about 10 seconds.
- Release the Reset button.
After the reset is complete, the LED on the front of the Base Station flashes amber. When the LED stops flashing amber, your Base Station reboots. - Remove the the Base Station or SmartHub from the account to prevent potential problems:
- Launch the Arlo Secure App or log in to your Arlo account at my.arlo.com.
- Tap or click Settings > My Devices and select the device that you want to remove.
- Scroll to the bottom of the page and tap or click Remove Device.
- Tap or click Yes to confirm you want to remove the device.
- Follow the steps below to re-add and set up your Base Station or SmartHub.
To re-add and set up your Base Station or SmartHub:
- On the Devices page, tap Add New Device.
- Select Base Station/Hub.
- Follow the prompts to reconnect your Base Station or SmartHub to your Arlo account.
- Use the Arlo Secure App to add and set up the rest of your Arlo devices.
