Why am I not receiving Arlo notifications on my iOS device?
To ensure that you receive push notifications:
Make sure you are logged into the Arlo Secure App on your iOS device.
- If you are logged out of the Arlo Secure App, you will not receive notifications on your device.
Make sure your Arlo devices are Armed.
- Launch the Arlo Secure App.
- Tap Mode.
- Select your Arlo device or tap Arm All Devices.
- If you selected a device, select Armed on the next screen.
Make sure Push Notification is selected in the Arlo Secure App for the Mode and Rule you are using when the camera is Armed.
- Tap Mode.
- Select your Arlo device.
- Tap the pencil icon next to the Armed or Custom Mode you are using.
- Tap the pencil icon next to the Rule.
- Scroll down to Alert and make sure Push Notification is selected.
Make sure Notifications are enabled on your iOS device for the Arlo Secure App.
- Launch the Settings App on your iOS device.
- Scroll down to your app list and tap Arlo Secure.
- Tap Notifications.
- Tap the Allow Notifications switch to toggle it to the On position (green).
- Select the types of alerts you wish to use.
Make sure Mute Notifications is set to Off in the Arlo Secure App.
- Tap Settings.
- If Mute Notifications is not set to Off, tap Mute Notifications.
- Tap Unmute.
Make sure your iOS device is not in Do Not Disturb or other Focus modes.
Focus modes will silence your notifications. If you are not receiving Arlo alerts, check to make sure Focus modes are turned off.
- Launch the Settings app on your iOS device.
- Tap Focus.
- Tap Do Not Disturb.
- If the Do Not Disturb switch is set to On (green), tap the switch to toggle it to the Off position.
- Tap < Focus to go back to the main Focus menu.
- Check to make sure that other Focus settings (Driving, Sleep, Personal, Work) are also off.
Make sure your iOS device is not in Low Power mode.
- Tap Battery.
- If the Low Power Mode switch is set to On (green), tap the switch to toggle it to the Off position.
Make sure you have not enabled Scheduled Summary on your iOS device.
Scheduled Summary bundles notifications and delivers them at times you set. If you use this feature, remove the Arlo Secure app from the list to ensure you get notifications for Arlo at all times.
- Tap Scheduled Summary.
- Toggle the Scheduled Summary switch to the Off position to turn the feature off completely, or scroll down to APPS IN SUMMARY and toggle the Arlo Secure switch to the Off position.
Check the App Store to ensure you have the latest version of the Arlo Secure App downloaded to your mobile device.
- If there is an update available, tap UPDATE to download the newest version.
For more information about email alerts, visit Why am I not getting Arlo email alerts?.
