Arlo Go 2 LTE / WiFi Security Camera FAQs
Learn about the Arlo Go 2 Security Camera with both WiFi and wireless LTE connectivity.
Go 2 Features
What’s the difference between Arlo Go and Arlo Go 2 Cameras?
The redesigned Arlo Go 2 is loaded with new features like LTE and WiFi connectivity, 1080p video resolution, color night vision, a spotlight, two-way audio, a siren, and GPS camera location.Where can I use a Go 2?
Monitor nearly any location with a WiFi or LTE connection. The camera is portable so you can take it with you and rely on a backup connection to the cellular network to ensure your cameras remain armed even when WiFi is unavailable.Is it better to connect to a WiFi signal or wireless mobile signal on my Go 2?
Go 2 is designed to be flexible. For example, you can use your WiFi with cellular mode as a backup, so you’re always protected even if the WiFi goes out. Or you can take your Go 2 to a remote location with no WiFi and use LTE mode by itself. To learn more about both options, visit What are the benefits of connecting my Go 2 Camera via mobile or WiFi?Do I need a SIM card for Arlo Go 2 mobile coverage?
Yes. Your Arlo Go 2 camera requires an activated SIM card with a mobile data plan to access the mobile network. For help with your mobile service plan, contact the carrier of the SIM card that was provided. If no SIM card was included, visit your local wireless carrier to activate a service plan and receive a SIM card.What options do I have if I do not have an activated SIM card?
If you do not have an activated SIM card, you can set up the device WiFi mode. To learn more, visit What are the benefits of connecting my Go 2 Camera via mobile or WiFi?Does the Go 2 come with an Arlo subscription?
Go 2 has a free 3-month subscription to Arlo Secure. Some retailers will also sell Go 2 with a voucher for an additional 24-months of Arlo Secure. This voucher will be included in the box.What are the storage options for the Go 2?
Use your Arlo Secure subscription to store videos in the cloud. Or install a microSD card (not included) to store your data locally.
Go 2 Mobile Providers
- Which mobile service providers can I use with the Arlo Go 2?
Arlo Go 2 currently works with Verizon Wireless and T-Mobile.
- How much cellular data does the Go 2 use?
Data use varies based on your environment and mobile service provider. Data consumption should range from 700MB to 2GB on a monthly basis, depending on the number of motion triggers and length of recordings.
To monitor Go 2 cellular data usage, contact your wireless provider. Learn more:
Go 2 Installation
Is the Arlo Go 2 battery powered?
Yes. The Go 2 has an extra-large rechargeable lithium polymer battery and does not require wiring. To learn more about installation, visit How do I insert the battery in my Arlo Go 2 camera?.Where should I place the Arlo Go 2?
For best results, we recommend placing your Arlo Go camera in a location where the Arlo app displays at least three bars of mobile network signal strength. To optimize signal strength, visit How can I optimize mobile signal strength for my Arlo Go series camera?.How do I use the GPS location feature?
The Go 2 Camera has outdoor GPS in case you install it in a remote area and need help finding it later. Learn more: Use GPS to locate an Arlo Go 2 Camera.
Go 2 Accessories and Partners
Which Arlo accessories are compatible with the Arlo Go 2?
Outdoor Mounts
VMA1000-10000S (white)
VMA1000B-10000S (black)Dual-Battery Charging Station
VMA5400C-100xxSSolar Panel Charger
VMA5600-100SExtra Rechargeable Battery
VMA5420-10000SMagnetic Indoor/Outdoor Charging Cable
VMA5600C-100xxS (white)
VMA5601C-100xxS (black)Indoor Charging Adapter
VMA5000C-100xxS (white)
VMA5001C-100xxS (black)Black Housing
VMA3800H-100S
- Which smart home services does the Go 2 support?
Go 2 works with Alexa, IFTTT, Google Home/Google Assistant.
