How do I trigger the floodlight on my Arlo Pro 3 Floodlight Camera?
You can manually trigger your floodlight or set it to trigger automatically when motion is detected, audio is detected, or when a device cross-triggers the floodlight.
Manual trigger
You can manually activate the floodlight on your Arlo Pro 3 Floodlight Camera by tapping or clicking the on/off switch in the Arlo app.
To manually turn the floodlight on or off for your Arlo Pro 3 Floodlight Camera:
- Launch the Arlo app or log in to my.arlo.com.
The Devices page displays. - Tap or click the On/Off switch on the device card to turn on or off your floodlight.
Note: If you do not manually turn off the floodlight, it will stay on for 1 to 20 minutes. To change the amount of time that the floodlight stays on, visit How do I adjust the light settings on my Arlo Pro 3 Floodlight Camera?. - To increase or decrease the floodlight brightness, tap or click and drag the slider to the right or left.
Note: Increasing the brightness uses a greater amount of battery life.
A countdown timer appears next to the light switch when the light is turned on. When the timer ends, the light turns off.
Automated trigger and cross-trigger
You can set the floodlight on your Arlo Pro 3 Floodlight Camera to activate when motion is detected, audio is detected, or when someone presses your Arlo Video Doorbell or Audio Doorbell. You can also cross-trigger your Arlo Pro 3 Floodlight Camera when motion or audio is detected on a different Arlo camera or doorbell.
To set your floodlight to automatically trigger when motion or audio is detected:
- Tap or click the Mode tab.
- Select your Arlo Pro 3 Floodlight Camera or the base station it is connected to.
- Tap or click the pencil (edit) icon, next to an existing mode, or tap or click Add a Mode.
- Follow the Arlo app instructions to set your floodlight to activate when motion and/or audio is detected.
If you are editing an existing mode, tap or click the pencil (edit) icon next to each rule that you want to edit.
When your Arlo Pro 3 Floodlight Camera is set to the armed mode that you created, the floodlight turns on when motion and/or audio is detected.
To automatically cross-trigger the floodlight and/or camera:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
The Devices page displays. - Tap or click the Mode tab.
- Select your Arlo Pro 3 Floodlight Camera.
Note: Your Arlo Pro 3 Floodlight Camera must be connected to the same Arlo account as the Arlo camera that you want to use for cross-triggering. - Tap or click the pencil (edit) icon, next to a mode, or tap or click Add a Mode.
- Follow the Arlo app instructions to activate your Arlo Pro 3 Floodlight Camera when motion or audio is detected on a different device or when someone presses your Arlo Video Doorbell or Audio Doorbell.
For help changing the light settings on your Pro 3 Floodlight Camera, visit How do I adjust the light settings on my Arlo Pro 3 Floodlight Camera?.
