How can I specify APN settings for my Arlo Go 2 Camera’s LTE connection?
In most situations, the access point network (APN) settings are automatically set up and you don’t need to enter them for the activated SIM card in your Go 2 Camera. If your mobile network provider instructs you to enter the APN settings, you can use the Arlo app to do so.
To specify APN settings for the activated SIM card in your Arlo Go 2 Camera:
- Launch the Arlo app.
- On the Devices page, tap the Settings icon for your Go 2 camera.
- Tap Connected to > Cellular Network > APN Settings.
- Enter the APN settings.
