How do I use HDR with my Arlo camera?
Last updated: 08.01.2025
High Dynamic Range (HDR) is a software method of adjusting high-contrast video or photo images that include areas of bright highlight and deep shadow. Without HDR, some images with bright areas can appear washed out, while dark areas can appear black, without detail. HDR makes it possible to see detail in both the highlights and shadows.
Your camera comes with an Auto HDR feature that is enabled by default. When your camera detects an image that would benefit from HDR, it automatically applies HDR unless you disable Auto HDR in the Arlo Secure App.
Auto HDR On:
Auto HDR Off:
To turn off Auto HDR:
For the Arlo Secure App experience with Feed:
- Launch the Arlo Secure App.
- Tap Devices.
- Select your Arlo device.
- Tap
- Tap Video Settings.
- Tap the Auto HDR switch to the off position.
For the Arlo Secure App experience with Library:
- Tap Settings.
- Tap My Devices.
