How do I connect my Arlo device directly to my Wi-Fi router if the camera is currently connected to an Arlo SmartHub or Base Station?
Last updated: 08.01.2025
Follow these instructions if your Arlo Camera or Arlo Video Doorbell is currently set up and connected to a VMB5000, VMB4540, VMB4500, or VMB4000 Arlo SmartHub or Base Station, and you want to connect the camera or doorbell directly to your 2.4 GHz Wi-Fi network.
If your Arlo camera is not already set up, visit: How to set up Arlo Cameras
Before you begin:
- You must have an Arlo Camera or Arlo Video Doorbell that can directly connect to a Wi-Fi router.
- Your mobile device must be connected to your 2.4 GHz Wi-Fi network, and you must connect your Arlo device to the same 2.4 GHz Wi-Fi network. For more information, visit: How do I connect my mobile device to a 2.4 GHz Wi-Fi network to set up my Arlo camera?
- To avoid losing your Arlo plan trial, make sure you add your Arlo device to the account that it was originally connected to.
- When your Arlo device is not connected to an Arlo SmartHub or Base Station, you cannot store recordings to a local storage device.
- Arlo Pro 5S and Arlo Pro 5 cameras can use the 5 GHz network, however, the camera needs to connect to a 2.4 GHz Wi-Fi network first when re-adding it to your Arlo account. For more information, visit: How does the Arlo Pro 5S camera use 5 GHz Wi-Fi networks?
To connect your Arlo Camera or Arlo Video Doorbell to a 2.4 GHz Wi-Fi router:
To switch your Arlo device from an Arlo SmartHub or Base Station connection to a direct Wi-Fi connection, you must remove the Arlo Camera or Arlo Video Doorbell from your account and then re-add it to the account using the Connect without SmartHub option.
- Launch the Arlo Secure App.
- Tap Devices.
- Tap your Arlo Camera or Arlo Video Doorbell device card.
- Tap
- Tap your Arlo device name at the top of the Device Settings screen.
- Tap Remove Device at the bottom of the Device Info screen.
- Tap Yes to confirm the deactivation of your device.
- Return to the Devices screen.
- Make sure you have the correct Location selected. For more information, visit: How do I switch my Location in the Arlo Secure App?
- Tap
- Select your Arlo device.
- Select your Arlo model.
- If Arlo detects that you have an Arlo SmartHub or Base Station, tap Connect without SmartHub.
- Tap Continue on the Connect to a 2.4 GHz network screen.
- Enter your 2.4 GHz Wi-Fi SSID and Password.
- Follow the in-app instructions to finish setting up your Arlo device.
