How do I adjust the light settings on my Arlo Pro 3 Floodlight Camera?
Last updated: 08.01.2025
Use the Arlo Secure App to adjust the Arlo Pro 3 Floodlight brightness, duration, and behavior. You can also disable and enable night vision and adjust ambient light sensitivity.
To adjust Arlo Pro 3 Floodlight Camera Light Settings (Brightness, Duration, and Behavior):
- Launch the Arlo Secure App.
- Tap Devices.
- Select your Arlo Pro 3 Floodlight.
- Tap
- Tap Light Settings.
- Move the Brightness slider left or right to adjust how bright your floodlight illuminates when activated.
Note: Increasing brightness reduces battery life. Connect the Arlo Pro 3 Floodlight Camera to continuous power with an Outdoor Charging Cable to avoid issues with battery life and increase the maximum brightness from 2000 to 3000 lumens. For more information, visit: How do I charge my Arlo Pro 3 Floodlight Camera? - Move the Duration slider left or right to determine how long your floodlight illuminates when activated.
Note: Increasing light duration reduces battery life. - Tap Behavior and select Constant or Pulsate to determine whether your floodlight illuminates continuously or flashes when activated.
To adjust Arlo Pro 3 Floodlight Camera Night Vision and Ambient Light Sensitivity:
- Tap Devices.
- Tap
- Tap Night Vision.
- Tap the Night Vision switch to enable or disable night vision.
Note: When night vision is enabled, the camera automatically turns on infrared LEDs to record in low light conditions. Disable night vision if the camera is facing reflective surfaces, such as windows. - Move the Ambient Light Sensitivity slider left or right to determine when the light will turn on and off when using night vision.
