Arlo Essential Outdoor Camera (2nd Generation) FAQ
This FAQ applies to the new Arlo Essential Outdoor Camera (2nd Generation).
What new 2nd Generation Arlo Essential Outdoor Camera models are available?
- Arlo Essential Outdoor Camera 2K (VMC3050)
 - Arlo Essential XL Outdoor Camera 2K (VMC3052)
 - Arlo Essential Outdoor Camera HD (VMC2050)
 - Arlo Essential XL Outdoor Camera HD (VMC2052)
What is the difference between the four 2nd Generation Arlo Essential Outdoor Cameras?
Arlo Essential Outdoor HD and Arlo Essential XL Outdoor HD camera models capture video in 1080p resolution. Arlo Essential Outdoor 2K and Arlo Essential XL Outdoor 2K capture video in 2K resolution.
The Arlo Essential XL Outdoor 2K and HD cameras come with an integrated extra-length (XL) battery, which provides additional battery life.
What are the key features of the Arlo Essential Outdoor Camera (2nd Generation)?
- Motion Detection Alerts
 - Color Night Vision
 - Noise-Canceling Audio
 - Integrated Spotlight
 - Integrated Siren
 - Weather Resistant
 - Direct to Wi-Fi Connection
Are the Arlo Essential Outdoor (2nd Generation) cameras completely wire-free?
Yes. The Arlo Essential Outdoor (2nd Generation) cameras are fully wire-free and powered with an integrated battery. However, you can use the Arlo Essential Solar Panel (2nd Generation) and Arlo Essential Outdoor Charging Cable (2nd Generation) to keep your camera outdoors with continuous power.
Can I use the Arlo Essential Outdoor (2nd Generation) cameras indoors and outdoors?
Yes. The Arlo Essential Outdoor (2nd Generation) cameras are weather resistant, wire-free, and outdoor compatible. They do not require a continuous AC power connection.
What is the minimum upload bandwidth speed required?
You must have a high-speed Internet connection that can sustain a minimum of 2 Mbps upload per Arlo Essential Outdoor Camera. For more information, visit: What are the minimum requirements for installing and using my Arlo system?
What is the Arlo Essential Outdoor Camera (2nd Generation) video resolution?
The Arlo Essential Outdoor Camera HD (2nd Generation) and Arlo Essential XL Outdoor Camera HD (2nd Generation) record and output Full HD 1080p at a 16:9 aspect ratio. The Arlo Essential Outdoor Camera 2K (2nd Generation) and Arlo Essential XL Outdoor Camera 2K (2nd Generation) record and output 2K video at a 16:9 aspect ratio.
How wide is the Arlo Essential Outdoor Camera (2nd Generation) viewing angle?
The camera lens provides a 130-degree field of view (FOV).
Do the Arlo Essential Outdoor (2nd Generation) cameras have color night vision?
Yes. All four versions of the Arlo Essential Outdoor Camera (2nd Generation) include color night vision.
How much longer does the Arlo Essential XL Outdoor Camera (2nd Generation) battery last?
The Arlo Essential XL Outdoor Camera 2K and Essential XL Outdoor Camera HD come with an integrated extra-length (XL) battery that lasts two years without charging. The Arlo Essential Outdoor Camera HD and Arlo Essential Outdoor Camera 2K both come with an integrated battery that lasts six months without charging.
Can I remove the battery in my Arlo Essential Outdoor (2nd Generation) camera?
No. The battery in your Arlo Essential Outdoor Camera is fully integrated and cannot be removed. You can recharge the Arlo Essential Outdoor Camera with the indoor charging cable that is included with the camera.
Can I use a solar panel to charge my Arlo Essential Outdoor (2nd Generation) camera?
Yes. Your Arlo Essential Outdoor Camera (2nd Generation) is compatible with the Arlo Essential Solar Panel (2nd Generation).
What kind of charging cable can I use with my 2nd Generation Arlo Essential Outdoor Camera?
Your Arlo Essential Outdoor Camera (2nd Generation) comes with a USB-C charging cable that you can use to charge your camera indoors. You can also use the Arlo Essential Solar Panel (2nd Generation) and Arlo Essential Outdoor Charging Cable (2nd Generation) to charge your camera outdoors.
What kind of power adapter can I use with the indoor charging cable that came with my camera?
To charge your Arlo Essential Outdoor Camera (2nd Generation), plug the included charging cable into any USB power source. Power sources with higher wattage charge your camera faster, Arlo recommends using at least 5V-2A.
Can I use my Arlo Essential Outdoor Camera (2nd Generation) to cross-trigger other Arlo cameras?
Yes. You can set your other Arlo cameras to record when your Arlo Essential Outdoor Camera (2nd Generation) detects motion.
What mounting options do I have with my Arlo Essential Outdoor Camera (2nd Generation)?
Your Arlo Essential Outdoor Camera (2nd Generation) comes with an adjustable screw mount that you can use indoors or outdoors. You can also visit Arlo.com to search for additional mounting accessories.
Last Updated:12/15/2023 | Article ID: 000063189
