What do I need to know about Arlo Wire-Free Camera (VMC3030) batteries?
Last updated: 08.01.2025
Recommended Arlo Wire-Free Camera (VMC3030) batteries:
  • The batteries supplied by Arlo with your Arlo Wire-Free camera
  • Tenergy Li-ion RCR123A 3.7V 650mAh rechargeable batteries specifically marked Works with Arlo
  • Non-rechargeable batteries from other high quality, established, well-known manufacturers such as Panasonic®, Energizer®, or Duracell®
  • For information about battery safety, visit: Safety Rules for Arlo Non-Rechargeable Batteries
Condtions that affect battery life:
  • Low Light
    • Your Arlo Wire-Free camera uses infrared sensors to monitor motion in the dark, which use more battery power than cameras monitoring motion in a well-lit room.
  • Poor Connection to the Arlo Base Station
    • Arlo cameras work well when they have a strong Wi-Fi connection to the Arlo Base Station.
    • Cameras positioned far away from the Arlo Base Station, cameras located in a noisy Wi-Fi environment, and cameras whose line of sight to the Arlo Base Station is heavily obstructed have a weaker connection.
    • If you have a noisy Wi-Fi environment, your Arlo camera battery might drain faster because your camera has to work harder to communicate with the Arlo Base Station.
    • For best results, position your Arlo cameras at least 6.5 feet (2 meters) away from each other and from other Wi-Fi enabled devices.
    • For more information about positioning your Arlo cameras, visit: Arlo Camera Placement Tips
  • Video Quality Settings
  • Cold Temperatures
    • Cold temperatures can affect battery capacity because the chemical reaction that produces electrical current takes place much more slowly in a cold environment.
    • If you install your Arlo camera outside in cold temperatures, you might notice a shorter battery duration for the camera, or a faster than expected drop in the displayed battery capacity.
    • For more information, visit: How do I keep my Arlo batteries charged in cold weather?
Battery icons in the Arlo Secure App:
