Arlo Solar Panel Compatibility
Last updated: 08.01.2025
With the Arlo Solar Panel connected to the camera and receiving average sun exposure, your camera battery stays charged, so you don’t need to worry about recharging it. The solar panel is a great low-maintenance solution for outdoor camera installations in hard-to-reach areas.
Although the Arlo Solar Panel is designed to keep your Arlo camera’s battery fully charged, heavy usage of your camera can drain the camera battery faster than the solar panel can recharge it. The 2-watt Arlo Solar Panel is designed to provide year-round trickle charging to keep your Arlo camera battery charged, not to charge your camera battery from low to full.
VMA6600 Essential Solar Panel (2nd Generation)
The VMA6600 Essential Solar Panel (2nd Generation) works with the following cameras:
- Essential Outdoor Camera 2K (2nd Generation) VMC3050
- Essential XL Outdoor Camera 2K (2nd Generation) VMC3052
- Essential Outdoor Camera HD (2nd Generation) VMC2050
- Essential XL Outdoor Camera HD (2nd Generation) VMC2052
The VMA6600 Essential Solar Panel uses a USB-C connector.
VMA5600 Solar Panel
The VMA5600 Solar Panel works with the following cameras:
- Arlo Ultra 2 VMC5040
- Arlo Ultra VMC5040
- Arlo Pro 5S VMC4060P
- Arlo Pro 4 VMC4041P & VMC4050P
- Arlo Pro 3 VMC4040P
- Arlo Go 2 VML2030
- Arlo Pro 3 Floodlight Camera FB1001
The VMA5600 Solar Panel uses a magnetic charging connector.
The VMA5600 Solar Panel also works with the Arlo XL Housing and XL versions of these cameras.
For more information, visit: VMA5600 features and specifications
VMA4600 Solar Panel
The VMA4600 Solar Panel works with the following products:
- Arlo Pro 2 VMC4030P
- Arlo Pro VMC4030
- Arlo Go VML4030
- Arlo Security Light AL1101
The VMA4600 Solar Panel uses a Micro-USB connector.
WARNING: The VMA4600 Solar Panel is not compatible with Arlo Essential series cameras.
VMA3600 Solar Panel
The VMA3600 Solar Panel works with the following cameras:
- Arlo Essential Camera VMC2020
- Arlo Essential Spotlight Camera VMC2030
- Arlo Essential XL Spotlight Camera VMC2032
The VMA3600 Solar Panel uses a Micro-USB connector.
WARNING: The VMA3600 Solar Panel is not compatible with Arlo Pro series cameras, Arlo Go cameras, or Arlo Security Lights.
For more information, visit: VMA3600 features and specifications
