How do I edit two-step verification settings?
You can add or remove phone numbers and trusted devices for two-step verification in the Profile settings of the Arlo app.
For more information about two-step verification, along with a guide to setting it up, visit What is two-step verification and how do I set it up?.
To remove a trusted device or phone number for two-step verification:
  1. Launch the Arlo app or log in to my.arlo.com.
  2. Tap or click Settings > Profile > Login Settings > Two-Step Verification.
  3. Tap or click Edit at the top-right corner.
  4. Tap or click the trashcan icon next to a phone number or trusted device.
    Note: You can also add a new method by tapping or clicking Add SMS Verification or Add Trusted Device at the bottom of the screen.
  5. Tap or click Delete.
    The trusted device or phone number is removed for two-step verification.
To change your primary two-step verification method:
  4. Tap one of your existing two-step verification methods.
    The checkmark icon appears when you tap a method.
  5. Tap Save.
    Your primary two-step verification method is changed.
To add a two-step verification method:
  3. Tap or click Add Another Method.
  4. Select Trust This Device or Add SMS Verification.
    Note: If the device is already trusted, you can only select Add SMS Verification.
  5. Follow the app instructions.
For more information about your profile settings in the Arlo app, visit How do I edit my Profile in the Arlo app?.
