Arlo Ultra and Ultra 2 Product Tour
The Arlo Ultra 2 camera has the following integrated features:
- Spotlight: Activate the integrated spotlight manually, or set it to trigger when motion or sound is detected. For more information, visit How does the spotlight on my Arlo camera work?.
 - Light Sensor: The light sensor makes sure that your Arlo camera’s image is properly adjusted according to the setting. For more information, visit How do I use HDR with my Arlo camera?.
 - 4K Lens with 180-Degree Field of View: Never miss a detail with crystal clear 4K video quality and a wide viewing angle. For more information, visit How do I adjust the field of view on my Arlo camera?.
 - Speaker: Deter intruders by activating the siren on the integrated speaker. For more information, visit How do I turn the siren on my Arlo Ultra or Arlo Pro 3 camera on or off?.
 - Microphone: Use the dual microphones to reduce wind noise, and use the speaker for a full-duplex two-way conversation. For more information, visit How do I reduce wind noise on my Arlo Ultra camera?.
 - Camera LED: Determine the status of your Arlo camera by referring to the LED indicator. For more information, visit What do the different LED behaviors on my Arlo camera mean?.
 - Weather Resistant Camera Housing: Use your Arlo Ultra 2 camera indoors or outdoors. For more information, visit Are Arlo cameras weatherproof?.
 - Sync Button: Press and hold the sync button to factory reset your Arlo Ultra camera.
 - Charging Port: Take advantage of a simpler charging solution with the magnetic charging cable that came with your Arlo Ultra 2 camera. For more information, visit What is the magnetic charger that came with my Arlo Ultra or Pro 3 camera?.
 - Battery Access Button: Press the battery access button to replace your batteries or access the sync button. For more information, visit How do I change the battery in my Arlo Ultra or Arlo Pro 3 camera?.
 - Screw Mount Hole: Use the screw mount hole to attach your camera to an outdoor security mount. For more information, visit the Outdoor Security Mount product page.
