Arlo Ultra and Ultra 2 Product Tour
Last updated: 08.01.2025
Arlo Ultra cameras have the following integrated features:
- Spotlight: Activate the integrated spotlight manually, or set it to trigger when motion or sound is detected. For more information, visit: How does the spotlight on my Arlo camera work?
 - Light Sensor: The light sensor makes sure that your Arlo camera’s image is properly adjusted according to the setting. For more information, visit: How do I use HDR with my Arlo camera?
 - 4K Lens with 180-Degree Field of View: Never miss a detail with crystal clear 4K video quality and a wide viewing angle. For more information, visit: What is the field of view on my Arlo camera and how do I change it?
 - Speaker: Deter intruders by activating the siren on the integrated speaker. For more information, visit: How do I turn the siren on my Arlo camera on or off?
 - Microphone: Use the dual microphones to reduce wind noise, and use the speaker for a full-duplex two-way conversation. For more information, visit: How do I reduce wind noise on my Arlo Ultra camera?
 - Camera LED: Determine the status of your Arlo camera by referring to the LED indicator. For more information, visit: What do the different LED behaviors on my Arlo camera mean?
 - Weather Resistant Camera Housing: Use your Arlo Ultra 2 camera indoors or outdoors. For more information, visit: Are Arlo cameras weatherproof?
 - Sync Button: Press and hold the sync button to factory reset your Arlo Ultra camera.
 - Charging Port: Take advantage of a simpler charging solution with the magnetic charging cable that came with your Arlo Ultra 2 camera. For more information, visit: How do I charge my Arlo Ultra 2, Ultra, Pro 5S, Pro 4, Pro 3, or Go 2 camera with the magnetic charger?
 - Battery Access Button: Press the battery access button to replace your batteries or access the sync button. For more information, visit: How do I change the battery in my Arlo Ultra, Arlo Ultra 2, Arlo Pro 3, Arlo Pro 4, or Arlo Pro 5S camera?
 - Screw Mount Hole: Use the screw mount hole to attach your camera to an Outdoor Mount or Anti-Theft Mount.
