How do I use the wall anchors that came with my Arlo product?
Last updated: 08.01.2025
Wall anchors are optional parts that come with some Arlo products. You can use them to ensure a secure mounting for your Arlo device.
We recommend using wall anchors when mounting on drywall, brick, or tile.
To use the wall anchors that came with your Arlo product:
- Use a 15/64 inch (6mm) drill bit to drill holes into the wall where you plan to mount device.
Note: Make sure the holes are the same distance as the three openings on the mounting plate. - Place a wall anchor into each of the holes that you drilled.
Note: For a secure fit, you might need to hammer the wall anchor into the hole. - Align the wall plate with the wall anchors.
- While holding the wall plate over the wall anchors, use a Phillips-head screw driver to fasten a screw into each of the wall anchors.
You are ready to mount your Arlo device to the mounting plate. For help mounting an Arlo Pro 3 Floodlight Camera, visit How do I wall-mount my Arlo Pro 3 Floodlight Camera?.
