How do I update my Arlo firmware manually?
Last updated: 08.01.2025
Firmware updates are released automatically to all connected Arlo devices.
- Automatic updates happen between 3:00 a.m. and 5:00 a.m. local time to minimize camera downtime.
- You can wait until the update happens automatically, or you can update your firmware manually.
- During firmware updates, Arlo cameras will continue to detect motion and sound, and still record based on the currently selected mode.
Note: Arlo firmware updates happen automatically as long as the device is connected to an Arlo SmartHub or Base Station, or Wi-Fi network, and has at least 15% battery charge prior to updating. Do not turn off or disconnect your Arlo device while a firmware update is in progress.
- For more information, visit: What do I need to know about Arlo camera firmware updates?
To update your Arlo device firmware manually:
- Launch the Arlo Secure App.
- Tap Devices.
- Tap the device you want to update.
- Tap
- Tap the device name at the top of the Device Settings screen.
- Tap Firmware on the Device Info screen.
- If there is an update available on the Firmware screen, tap Update.
WARNING: Do not open battery doors, remove batteries, turn off, or unplug any Arlo device during a firmware update. - Wait for the firmware update to complete.
While the firmware is updating:- The LED on most Arlo cameras alternates blue and amber. After this, the camera LED turns off for about one to two minutes while the camera installs the firmware. After the camera firmware update finishes, the camera syncs and the LED blinks blue rapidly.
- Arlo Q, Arlo Q Plus, and Arlo Go 2: The camera LED alternates amber and blue while the firmware is updating. After the firmware is installed, the camera reboots and the LED turns off. When the LED comes back on and the pattern stops changing, your camera is available to stream.
- For more information, visit: What do the different LED behaviors on my Arlo camera mean?
To update your Arlo SmartHub or Base Station firmware manually:
- Tap Devices.
- Tap the Arlo SmartHub or Base Station you want to update.
- Tap the Arlo SmartHub or Base Station name at the top of the Device Settings screen.
WARNING: Do not turn off or unplug your Arlo SmartHub or Base Station while the firmware update is in progress. - Wait for the firmware update to complete.
While the firmware is updating:- The Arlo SmartHub LED alternates blue and amber during the firmware update. When the Arlo SmartHub LED is solid blue, the firmware update is complete.
- The Arlo Base Station LED blinks green during the firmware update. When the Power and Internet LEDs are solid green, the firmware update is complete.
- For more information, visit: What do the LEDs on my Arlo SmartHub or Base Station mean?
