How do I connect my Arlo device directly to a Wi-Fi router?
Last updated: 08.01.2025
When you first set up your Arlo camera, you have the option to connect the camera directly to your Wi-Fi router or to an Arlo SmartHub or Base Station. You can use the Arlo Secure App to connect directly to your Wi-Fi router.
To move your Arlo camera from an Arlo SmartHub or Base Station connection to a Wi-Fi router connection, visit: How do I connect my Arlo device directly to my Wi-Fi router if it is currently connected to a SmartHub or Base Station?
Note: When your Arlo camera is disconnected from an Arlo SmartHub or Base Station, you can no longer store Arlo recordings to a local storage device.
Before you begin:
- Your mobile device must be connected to your 2.4 GHz Wi-Fi network, and you must connect your Arlo camera to the same 2.4 GHz Wi-Fi network.
- For more information, visit: How do I connect my mobile device to a 2.4 GHz Wi-Fi network to set up my Arlo camera?
- Arlo Pro 5 cameras must be installed on a 2.4 GHz Wi-Fi first before connecting to a 5 GHz Wi-Fi network. If the SSID and password are the same for your 2.4 GHz and 5 GHz networks, the camera will automatically join both networks during installation.
- For more information, visit: How does the Arlo Pro 5S Camera use 5GHz Wi-Fi networks?
- Band Steering automatically connects your devices to the best available Wi-Fi frequency in your home. Most Wi-Fi modems come with two frequencies (2.4 GHz and 5 GHz) and ask you to choose between them when connecting a device to your home network.
- Disable Band Steering prior to installing your Arlo device.
- Upon successful installation and setup, you can re-enable Band Steering.
Note: Contact your router manufacturer for specific Band Steering instructions
To connect your Arlo camera directly to your 2.4 GHz Wi-Fi network:
- Launch the Arlo Secure App.
- Tap Devices.
- Tap
- Select your Arlo device.
- Select your Arlo model.
- Follow the in-app instructions.
- If Arlo detects that you have an Arlo SmartHub or Base Station, tap Connect without SmartHub.
- Tap Continue on the Connect to a 2.4 GHz network screen.
- Enter your 2.4 GHz Wi-Fi SSID and Password.
- Follow the in-app instructions to finish setting up your device.
Related links:
My Arlo camera will not scan the QR code during setup
What to do when Arlo is unable to discover your device during an install or setup directly to a Wi-Fi router
